It's true how the Law of Primacy works: you will best remember the first thing you learned about something. No matter how many other things you learn, you will tend to return to the first thing you learned.
And for pre-takeoff and pre-landing, you often have to use memory because your hands might be full and you don't have the luxury of a copilot to read a checklist for you.
For me, learning on the Huey, it was the VAs:
Hatches
Harness
Heaters
Electrics
Fuel - quantity, pressure, and selection
Instruments- in limits, lights out
Audio (Eng out or low rotor RPM audio switch - on)
Auto (FCU in auto mode, not manual)
Full throttle
6600 RPM
This same list has worked for me in every aircraft I have flown, from an R22 to a B412 and S76, but with some sensible additions. For example, with the S76 it went:
Hatches (all doors locked, as shown on the indicator panel)
Harness
Heaters (air conditioner off for takeoff or landing, unless doing a rolling runway takeoff)
Electrics (all gen and inverters on, loads indicating normal)
Fuel - quantity in both tanks, pressure, flow normal
Instruments - all gyro/glass screens erect/ready, compass aligned, Ts and Ps all normal
Audio - all radios and navs set, volume checked, monitor switches in appropriate spot, intercom checked
Auto - autopilot tested and in appropriate mode, pre-set altitudes, force trim as desired
Full throttle - both in Fly
RRPM - at 107%
Worked for me for 45 years, though for the final 5 years working in a military-style flying school, the students had to follow the printed checklist word for word for the B206.
Some of you will recoil in shock and go pale as you say "but..but... you MUST use the checklist for that aircraft, as per the RFM, or the insurance will be invalid, the sun will refuse to rise, and your coffee will forever be bitter!"
To you, I say, try this list against your printed list, and see if it misses anything. If it does miss an item, does it fit into any of the afore-mentioned headings? Give it a try.
But most of you will have the R22 as your first helicopter, so your Law of Primacy will be different from mine. And as you move on to more complex aircraft, you will need to learn different checklists, but you will never forget your checks for the Flimsicopter.
Hmm, that one doesn't flow well for me in my "flimsicopter". Lets see,...
Lights out
Speed green
Gauges green
Fuel ok
Carb heat ok
Trim in
,...ah' yes much better! :)
Mine checks off a lot of those boxes on its own as well. Canopies are always shut, harnesses always on, heat/ac always on, generators always on, fuel auto balances and quantity is always displayed, no autopilot, force trim always on. A quick physical/visual check of the power levers, select the correct MPD pages with a button or two and good to go.
Landing:
No warning lights, do I know what I'm doing? Ask crew if they're ready, tell crew to shush, make a radio call, proceed.
Takeoff:
No warning lights, do I know what I'm doing? Ask crew if they're ready, make a radio call, proceed.
  • 4 weeks later...
