TheJudasNut Posted December 1, 2019 Posted December 1, 2019 Greetings, I'm a seasoned fixed wing pilot looking into an add-on rating. I am looking into flying at a flight school that possesses both a Bell 47G-2 and a Bell 47G-4A. The G-2 is substantially less expensive per hour than the G-4A, but I'm concerned that the ship might not have the performance to train a man of my size. I'm 6' 2" and about 255, and the instructor in question is probably somewhere around 185. It goes without question that I will abide by and respect the owner/instructor's judgement with respect to performance, but I wanted to seek other opinions to better educate myself before I start making real moves. If you have a good bit of experience on the G2, and can speak to its capabilities as a trainer for a man my size, I'd be grateful to hear from you. Thank you in advance. -JN Quote
Canadian47 Posted December 7, 2019 Posted December 7, 2019 I have about 10 hours on a G2 and 400+ on my G4 (same engine, different transmission than a G4A). Question...Where are you located (more precisely, what is the density altitude like there when you will be training). Check the flight manual and check the IGE/OGE hover limits with you/instructor/full fuel. The G4 is wider but I get 3 people in all the time with one of my friends being over 6'4". I have also taken up numerous people in the 300# range with a kid/small person in the middle. A G2 with just you and the instructor should be more than adequate size wise. One thought is if the G2 has adequate performance, issues of cost aside, I would still choose the G2. The extra power of the G4A will cover up/compensate for a lot of bad technique. Learning in a machine closer to the limits will make you a better pilot. Glenn 1 Quote
helonorth Posted December 7, 2019 Posted December 7, 2019 Fly them both and see what works best. That's the only way you'll know. Quote
T6guy Posted January 14, 2020 Posted January 14, 2020 I’m interested in purchasing a G2 with VO 435-A1F engine. I’m a big guy and I need the W&B Arms for loading allowing me to create a few scenario’s to verify it will work for me. question: can someone give me the arms, I can’t find them anywhere and I don't have a POH. Quote
Mountain Marauder Posted February 16, 2021 Posted February 16, 2021 The G-2 will work fine. It's a lighter empty weight and an excellent performer. May as well start saving money now. Once you get hooked on helicopters you're going to want one. Have fun and good luck! Quote
Mountain Marauder Posted February 16, 2021 Posted February 16, 2021 On 1/14/2020 at 6:58 AM, T6guy said: I’m interested in purchasing a G2 with VO 435-A1F engine. I’m a big guy and I need the W&B Arms for loading allowing me to create a few scenario’s to verify it will work for me. question: can someone give me the arms, I can’t find them anywhere and I don't have a POH. That A1F engine will give you more power than you need unless you live up around 10,000'. Remember the transmission on the G-2 is rated for 200 HP and the A1F has 260 HP so you have the capability to use that extra HP to compensate for DA. I don't have a POH for the G-2 but the loaded CG (pilot, pax and fuel) is almost directly under the mast. On some G-2's the battery (if it's located aft of the engine) can be moved fore and aft to compensate for a typical nose heavy or tail heavy loading. I doubt if you'll have any CG issues if the EWCG is near mid limits. Quote
