Discap Posted April 8, 2020 Report Share Posted April 8, 2020 I am due to swap out the bleed valve on my Enstrom 480B in the next 25 hours. In looking at it, it seems to be what I would be termed in the car world as a "waste gate". I had assumed that it was a control valve but it appears to be simply a preset pressure relief valve. Can anyone share some light on what it does? Thanks Bill Quote Link to comment Share on other sites More sharing options...
iChris Posted April 11, 2020 Report Share Posted April 11, 2020 (edited) On 4/8/2020 at 9:39 AM, Discap said: I am due to swap out the bleed valve on my Enstrom 480B in the next 25 hours. In looking at it, it seems to be what I would be termed in the car world as a "waste gate". I had assumed that it was a control valve but it appears to be simply a preset pressure relief valve. Can anyone share some light on what it does? Thanks Bill The ability of the compressor to pump air is a function of RPM. At low RPMs, the compressor does not have the same ability to pump air as it does at higher RPMs. To keep the blade angle of attack and air velocity within desired limits and prevent compressor stall, it is necessary to "unload" the compressor in some manner. In other words, the compressor needs to see less restriction to the flow of air through the use of a compressor bleed air system. CLICK PHOTO TO ENLARGE Quote When the engine is not in operation, the bleed valve is positioned fully open by a spring located inside of the vented piston chamber. The spring along with Pi pressure, directed onto the bleed valve end, are used during engine starting and acceleration to position the bleed valve fully open. During engine operation, Pc pressure is directed through an inlet filter and a restrictor (jet) into the Px chamber. Px air is then directed to Pa through a nozzle (venturi). The rate of air flow from Pc to Px to Pa determines the value of Px pressure for any given N1 RPM. Px pressure is used to provide the closing force on the bleed valve. Px pressure is separated from the Pa pressure and spring chamber by means of the rolling diaphragm. Operation of the valve is a function of preselected ratios of Pi to Pa and Pc to Px to Pa pressures. When Px is less than Pi plus the spring force, the bleed valve is positioned open. When Px is greater than Pi plus the spring force, the bleed valve is positioned closed. The bleed valve is positioned open during engine starting and acceleration until the Px pressure increases sufficiently to overcome the combined value of the spring and Pa pressure. The bleed valve then closes and remains closed at all N1 speeds above the closing RPM. Allison Gas Turbine 1981 Edited April 11, 2020 by iChris Quote Link to comment Share on other sites More sharing options...
Discap Posted April 13, 2020 Author Report Share Posted April 13, 2020 Chris: Thanks for the help. I don't know where you find all this documentation. I looked and found nothing. I am always impressed Bill Quote Link to comment Share on other sites More sharing options...
adam32 Posted April 29, 2020 Report Share Posted April 29, 2020 The one and only time I had an "engine problem?" was when the bleed valve failed and it built pressure then rolled the engine back to idle by itself. Luckily it was in a Bell 212 at low weight and elevation so we got it figured out while flying on the 2nd engine. Quote Link to comment Share on other sites More sharing options...
