spencer Posted October 23, 2007 Posted October 23, 2007 I operate an r-44 out of an un-heated hanger right on the Ohio Michigan line (Toledo Ohio). It is starting to get cold and i wanted to hear some ideas on how to keep the aircraft warm without heating the whole hanger. Last year i bought some heating blankets and put one over the main rotor boots to prevent leaking and i put one over the cowling to try to keep the insides warm. I just wanted to see what some people do because maintenance costs killed me last year dealing with main rotor boot leaks and about a half dozen hydraulic leaks. Thanks Quote
RotorWeed Posted October 24, 2007 Posted October 24, 2007 I operate an r-44 out of an un-heated hanger right on the Ohio Michigan line (Toledo Ohio). It is starting to get cold and i wanted to hear some ideas on how to keep the aircraft warm without heating the whole hanger. Last year i bought some heating blankets and put one over the main rotor boots to prevent leaking and i put one over the cowling to try to keep the insides warm. I just wanted to see what some people do because maintenance costs killed me last year dealing with main rotor boot leaks and about a half dozen hydraulic leaks. Thanks I use a Tanis heater on my Robbie; it keeps the engine bay very warm. http://www.tanisaircraft.com/TAS100S-07%20R44.htm Quote
Gomer Pylot Posted October 25, 2007 Posted October 25, 2007 Sounds to me as if heating the entire hangar would be the cheapest way to go. You can pay for a lot of electricity, fuel oil, or gas for the price of a repair. Quote
delorean Posted October 25, 2007 Posted October 25, 2007 I would heat the hangar......Just heating parts is going to cause problems in the long run. The worst thing you can do is have a oil pan or engine block heater and leave it plugged in. Your going to build up all kinds of condensation inside of the crankcase and form corrosion on the crankshaft, camshaft, etc. You should only use those heaters a few hours prior to starting the engine (and then run the engine at temp for at least 20 minutes to cook all the moisture out of it.) You don't need to keep the hangar at a comfy 70 degrees, just keep it at 40-50. Sorry, probably not the advice you were looking for. Quote
Sparker Posted October 25, 2007 Posted October 25, 2007 You don't need to keep the hangar at a comfy 70 degrees, just keep it at 40-50. Sorry, probably not the advice you were looking for. but..but..but 70 feels so nice.... Quote
RotorWeed Posted October 25, 2007 Posted October 25, 2007 I would heat the hangar......Just heating parts is going to cause problems in the long run. The worst thing you can do is have a oil pan or engine block heater and leave it plugged in. Your going to build up all kinds of condensation inside of the crankcase and form corrosion on the crankshaft, camshaft, etc. You should only use those heaters a few hours prior to starting the engine (and then run the engine at temp for at least 20 minutes to cook all the moisture out of it.) You don't need to keep the hangar at a comfy 70 degrees, just keep it at 40-50. Sorry, probably not the advice you were looking for. If the hangar is not insulated, or it is 10k square; it might not feasible to heat the hangar. Also many lease agreements prohibit heaters. Quote
spencer Posted October 25, 2007 Author Posted October 25, 2007 The issue about heating the hanger is it is in the lease. Plus there are two airplanes in the hanger too which do not care about it being heated. I do have a tannis heater and i do use it. Quote
RotorWeed Posted October 25, 2007 Posted October 25, 2007 Did the heating blanket over the main rotor help at all? Quote
Superman Posted October 25, 2007 Posted October 25, 2007 We have a Tannis heater that I plug in 15-20 minutes before flying, or if it has to be left outside for any length of time, I don't like to leave it on all the time. What we use that has worked the best on both the helicopter and fixed wing is an LP gas forced air heater that we rigged up to blow hot air into the engine and we have a hose to preheat the cabin. Just runs off an LP gas grill tank and 110 power. Works real well. can have it nice and warm within 15 minutes or so. By the time you shovel the snow and get the doors pried open, your good to go!! I'll post a photo of it when I get home. We have a heated hangar, but we keep it around 40. 70 is nice but very expensive. Especially when it has a 60x20 hole in it. Next best option...... Fly south November one, return May one. Fly SafeClark Quote
Gomer Pylot Posted October 25, 2007 Posted October 25, 2007 Personally, I would look for another hangar. You have a lot of money tied up in the helicopter, and you're going to pour a lot more into it under those conditions. The maintenance issues become safety issues, and hospital stays aren't cheap. Quote
500E Posted October 25, 2007 Posted October 25, 2007 I am with GP on this one find another home the things to expensive to have corrosion \condensation eat it.We are lucky to have a insulated building with doors to keep ours in but also have a hot air heater controlled by a thermostat & humidity sensor, it is set to a low temp just enough to keep humidity at bay, then if it gets real cold we can crank it up for 15\20 min. to warm everything through. Quote
spencer Posted October 25, 2007 Author Posted October 25, 2007 It was in the same hanger all last winter and i never saw any condensation inside or anywhere on it. Preheating it is not an issue because i do plug a tannis heater into to it about 30 min before i go flying. At that same time i have a kerosene heater which i place behind the aircraft which it blows warm air all through the aircraft. The concern was to find a way to keep the cowlings semi-warm (above freezing temps) all the time. Quote
spencer Posted October 25, 2007 Author Posted October 25, 2007 Did the heating blanket over the main rotor help at all? I have to say it did. It kept the boots semi-warm which was the whole point. After i decided to put one on the boots i don't remember them leaking again. Quote
RotorWeed Posted October 26, 2007 Posted October 26, 2007 http://www.tanisaircraft.com/enginedehydrator.html I'm thinking about buying one of these for my helicopter; anyone ever use one? Do they work? Quote
MLH Posted October 26, 2007 Posted October 26, 2007 I have a Raven II that I kept in the hangar heated to 45 degrees most of last winter with no boot leakage. As soon as I pulled it out and went flying in 15 to 20 degrees, a few drops leaked out of each side. I was told that the best time to tighten the clamps (particularly the internal) was in the winter when it's cold. Others I know who have done this have not had any more leaks, even during cold weather flying. I'll see what happens this winter and be prepared to do the same. Winter is great for performance as well as not having to clean off the bugs after a flight. Quote
Gomer Pylot Posted October 27, 2007 Posted October 27, 2007 Winter is great for performance as well as not having to clean off the bugs after a flight.Well, maybe where you are. Down here, they don't slow down at all. We have everything from mosquitos to love bugs to big grasshoppers year round. Of course, not having 10 feet of snow on the ground has something to do with that, and I'll take the bugs. If you want to see something scary, turn on the landing light late some night and take a look at what's zooming by you. Sometimes it looks like rain down here. Quote
Witch Posted October 27, 2007 Posted October 27, 2007 (edited) Just a "Thinking outside the box" sort of thought: might a plastic tent covering the aircraft with a couple of space heaters do the trick? Maybe even one of those portable garage things like at Costco. Modify it to fit the bird and plug in a couple of those space heaters. Kinda like a hangar in a hangar. I know, stupid idea. Later Edited October 27, 2007 by Witch Quote
Sparker Posted October 27, 2007 Posted October 27, 2007 Just a "Thinking outside the box" sort of thought: might a plastic tent covering the aircraft with a couple of space heaters do the trick? Maybe even one of those portable garage things like at Costco. Modify it to fit the bird and plug in a couple of those space heaters. Kinda like a hangar in a hangar. I know, stupid idea. Later Sounds like a recipe for an insurance claim.... of course, maybe then they could afford a heated hangar..... Those oil radiator heaters are fairly safe, though... not much risk of fire with them guys. Quote
