RagMan Posted July 23, 2011 Posted July 23, 2011 Any of you 206 pilots ever heard of "spike lock"? One of my military buddies who trained on the TH-57 through Army flight school mentioned it to me today. I haven't heard of the term yet in my 206 turbine transition, but then again, it might be one of those things that the Army enjoys creating. I've searched around a bit on google but haven't found anything yet. He could be screwing with me, but he seems pretty serious about it. Thanks in advance. Quote
heligirl03 Posted July 23, 2011 Posted July 23, 2011 Do they mean jack lock? Or servo transparency? In relation to hydraulics. Haven't heard it called spike lock yet but I've only been around a few years so what do I know?! edit: also jack stall, servo reversibility, and probably a million other terms that I also haven't heard of Quote
palmfish Posted July 23, 2011 Posted July 23, 2011 Could he have said, "Spike Knock?" "Spike knock occurs when the round pin in the drag-pin fitting contacts the side of the square hole of the pylon stop, which is mounted to the roof. It creates a loud noise and will occur during a rocking of the pylon. The following factors can cause spike knock, low rotor RPM, extreme asymmetric loading, poor execution of an autorotational landing and low G maneuvers below +.5 Gs." I had to wear a golden railroad spike around my neck and memorize that quote from the OH-58 -10 many moons ago... 2 Quote
heligirl03 Posted July 23, 2011 Posted July 23, 2011 I had to wear a golden railroad spike around my neck and memorize that quote from the OH-58 -10 many moons ago... Lol. Good info though! I'll be in town next month a week or two, you out on ERAD or will you be local? Quote
SBuzzkill Posted July 23, 2011 Posted July 23, 2011 (edited) Could he have said, "Spike Knock?" "Spike knock occurs when the round pin in the drag-pin fitting contacts the side of the square hole of the pylon stop, which is mounted to the roof. It creates a loud noise and will occur during a rocking of the pylon. The following factors can cause spike knock, low rotor RPM, extreme asymmetric loading, poor execution of an autorotational landing and low G maneuvers below +.5 Gs." I had to wear a golden railroad spike around my neck and memorize that quote from the OH-58 -10 many moons ago... LOTS of quoting that during Primary, albeit in the TH-67. Edited July 23, 2011 by SBuzzkill Quote
RagMan Posted July 23, 2011 Author Posted July 23, 2011 Could he have said, "Spike Knock?""Spike knock occurs when the round pin in the drag-pin fitting contacts the side of the square hole of the pylon stop, which is mounted to the roof. It creates a loud noise and will occur during a rocking of the pylon. The following factors can cause spike knock, low rotor RPM, extreme asymmetric loading, poor execution of an autorotational landing and low G maneuvers below +.5 Gs."I had to wear a golden railroad spike around my neck and memorize that quote from the OH-58 -10 many moons ago... Thanks for clearing that up, Palmfish! I knew the purpose behind the drag pin and why its there, just haven't heard of that term before and what it correlated to. Quote
AngelFire_91 Posted July 23, 2011 Posted July 23, 2011 Palmfish is correct. We (not me) had a bad practice auto once where the spike knock was so bad it broke the inner pylon stop, and busted the rivets on the outer plate that holds it in place, YIKES! Quote
arotrhd Posted July 23, 2011 Posted July 23, 2011 x3 on Spike Knock. -WATCH FOR THE PATTERNS, WATCH FOR THE WIRES- Quote
palmfish Posted July 23, 2011 Posted July 23, 2011 Lol. Good info though! I'll be in town next month a week or two, you out on ERAD or will you be local? I'm on erad through Aug 5th. I'm then heading up to AK with the Soloy on the 17th for a few weeks. I'd love to see you if you can fit me in! Quote
heligirl03 Posted July 24, 2011 Posted July 24, 2011 I'm on erad through Aug 5th. I'm then heading up to AK with the Soloy on the 17th for a few weeks. I'd love to see you if you can fit me in! Perfect, I'll be there the 10th-16th! I'll give you a call after the 5th, we can figure something out. Jealous of AK as always! Quote
palmfish Posted July 24, 2011 Posted July 24, 2011 Perfect, I'll be there the 10th-16th! I'll give you a call after the 5th, we can figure something out. Jealous of AK as always! Great, I'll wait to hear from you. One of these days I'll take the AStar up there. I get jealous every time I see a helicopter while I'm buzzing around up there in the Cessna. Quote
copter1507 Posted November 28, 2020 Posted November 28, 2020 Can’t remember hearing the phase “spike knock” while flying the TH-55 during army flight school in 1982. We called it “mast bump” while flying the UH-1. Scarcely a whisper of spike knock was heard until transitioning into the OH-58 where the whisper quickly became a roar! Spike knock was always a serious concern if autorotation landings ended with touching down too hard on the heels of the skids. Leveling aircraft with tittering rotor systems just prior to touch down was the trick to keeping mast damage at bay. Overly steep slope landings could cause knock/mast bump as well. Thankfully never encountered that particular bogyman during 32 years of “beating the air into submission” in the military. Quote
SBuzzkill Posted November 29, 2020 Posted November 29, 2020 (edited) Spike knock was common and different than mast bump, and refers to a design feature of the Bell 206... I think you're confusing terms. Edited November 29, 2020 by SBuzzkill 1 Quote
Eric Hunt Posted December 9, 2020 Posted December 9, 2020 The spike is at the bottom of the Txmsn, in its little hole, able to move around with flexes in the Txmsn mounts. However, if the Txmsn moves too far, like a heavy landing, the spike will knock against the side, and leave a mark on the spike. The metal edges are of a softer material than the spike. 2 Quote
