So as an instructor, I figured that we can use this forum to share teaching tips and ideas to make learning to fly helicopters easier. So I was hoping to compile a list of all the different acronyms we all use to make remembering things easier.
I figure that I may have some acronyms that you may not have and you can add it to your list and maybe make learning something easier, and likewise you may have an acronym that may surprise me and help me and my students remember some things. So I hope that you all help and pitch in with your own.
1. Compass Errors
VDMONA or MONA has VD
Variation, Deviation, Magnetic Dip, Occilation, Northern Turning Errors, Acceleration Errors
2. FAA Required Equipment (91.205)
CAMALS FOOT
Compass, ASI, Manifold Pressure Gauge, Altimeter, Lights, Seatbelts, Fuel Gauge, Oil Pressure, Oil Temperature Gauge, Tachometer
3. Robinson Requiered Equipment
G COLA
Governer, Cylinder Head Temp, Outside Air Temp, Low Rotor Warning, Lights(night), Alternator
4. Preflight Check
WFKART
Weather, Fuel requirements, Known Traffic Delays, Alternates, Runway Length, takeoff/landing distances
5. Equipment required for night flight
FLAPE
Fuses, Landing Lights, Anti-collision lights, Position Lights, Electrical Source
6. Different Types of FOG
SPURAG (Spew Rag)
Steam, Precipitation, Upslope, Radiation, Advection, Ground
7. Pre-landing IFR checks
WRIMTIM
Weather code, Radios, Identify, minimums, Time, Instruments, Missed
8. Paperwork needed in the aircraft
AROW
Airworthiness, Registration, Owners Manual, Weight and Balance
9. Special Use Airspace
MCWRAP
MOA, Controlled Firing, Warning, Restricted, Alert, Prohibited
10. Other Use Airpsace
PATTMAN
Parachute, Airport Advisory Area, TRSA, Temporary Flight Restrictions, MTR, ADIZ, National Security Area
11. Equipent required for IFR Flight
GGGICARA (The G's all stand for gyro meaning the 3 gyro instruments)
HSI/HI, AI, TC, Inclonometer Ball, Clock, Altimeter, Radios, Alternator
12. IFR Reports in a Radar Environment
VACUMFLLS
Vacating for an newly assigned altitude, Altitude change in VFR-on-top, Change in average airpseed, Unable to climb/descend, Missed, Fix arrival, Leaving a fix, Loss of nav equipment, Safety of flight
13. IFR Reports not in a Radar Environment
EPIC
Estamated time >3 minutes, PIREPS, Inbound from the fix, Compulsory Reporting Points
14. Equipment malfunction in IFR
DEAN
Degree of ability to continue, Equipment Affected, Aircraft ID, Nature of assistance needed
15. Info included in a position report IFR
PANTIPE
Postion, Altitude, Next Reporting Point, Type of flight plan, ID, Pertainent Remarks, Estimated Time
WTF - What you say when you see the list of acronyms (there's one at the end of the AIM (yet another acronym...dude!)) :o
I use grabcard for ifr required instruments,
Generator-alternator/source of power
Radios
Altimeter- pressure sensitive altimeter
Ball-inclinometer
Clock-clock with second hand
Attitude indicator
Rate of turn indicator-turn coordinator or turn and slip
Directional gyro
Good list so far
There should be quite a few for high recon, low recon also
N1 Drives SOFTC
Starter/Generator
Oil Pump
Fuel Control Unit/Engine Driven Fuel Pump
Tach Generator(N1)
Compressor
N2 Drives TONE
Torque Meter/ or TQ Meter Boost Pump
Overspeed Governer/PTG
N2 Tach Generator
Engine Output Shaft
Transponder codes
75(00) Dead or alive
76(00) No clicks
77(00) going to heaven
I use 75(00) Obama's inside (Hijacking) and yes I know it's supposed to be Osama but I like to use Obama. ;)
And if you have trouble remembering all these, here's a acronym for that, too:
AROW
HEAT-SAM
Twenty/30 Rule
Two/1 Flight Time
CAMAFOOTS
TOMATOE A FLAMES
GOAL-T
NAIL-GI/CI
FLAPS
GRABCARD-N
Taken alive, In a fix, Goin’ to heaven
AVE-F, MEA, Clearance Limit
IP-TA-FERR
NEDD
AVRRRRTTTTTT Normal Vis
VAAAACUM Loss Compromises Final ETA
RAFT-V
SIX T’s
TIMES ABC
Very Good Airmen Do Procedures Right
ANDS
UNOS
IFR Certified GPS in lieu of ADF and DME
Weather within lateral limits of B, C, D, E to the SFC
Substitutes for OM and MM
= AHTTCTGNFGTAINAVRSTVAUIWS
Makes it pretty easy, I think.
  • 3 weeks later...
For IFR Approach setup and brief, I love the 5 A's
Atis
Altimeter
Alignment
Avionics
Approach Brief
For IFR currency, you must get your sh*t together.
Six approaches
Holding
Intercepting
Tracking
Transponder codes
76(00) No clicks
Mine was very similar
I learned 75 stay alive 76 radio tricks 77 go to heaven
I don't get the ones for hijacking?
77 go to heaven,...and people call me a pessimist? :lol:
:rolleyes: I guess the good thing is there are no numbers that rhyme with hell, so heaven is kind of optimistic...if you gotta go :P
All the IFR acronyms I could think of....
5 T's
Time
Turn
Twist
Throttle
Talk
WRIMTIM's (enroute checks)
Wx
Radios
Instruments (no flags, courses set, etc)
Minimums
Time
Ident
Missed Approach Procedure
IFR Currency
6 approaches
Holds
Intercepting
Tracking
Six months
VOR Checks
VOT Test Facility
Own wpt
Dual VORs
Ground
Airway
(and when making the entry in the mx log, remember...)
Signature
Place tested
Error detected
Date tested
When to talk to ATC
Safety of flight
Missed Approach Point
Entering Hold
Leaving Hold
Leaving Altitude
Leaving FAF
True Airspeed Change +/- 10 knots or 5%, whichever is higher
Unforecast Weather
VFR On Top
Loss of Comm/Nav
Unable to climb/descend at least 500 fpm
ETA Change >3 mins
-OR-
Safety of flight
Weather unforecast
Altitude Change
Missed Approach
Performance Change (+/-10 knots or 5%)
Instrument Malfunction
Entering/Exiting Hold
IFR loss of comms
Fly Route:
Route last assigned
Vectored
Expected
Filed
Fly Altitude:
MEA
Expected
Assigned
and finally....
Equipment needed for IFR flight
Generator/Alternator
Radio
Altimeter (sensitive)
Ball slip/skid indicator
Clock with hrs, mins and sec
Attitude Indicator
Directional Gyro
PLUS
Compass
Airspeed Ind.
MAP
Alt
Lights
Fuel gauge
Oil Temp
Oil Pressure
Tach
Seatbelt
time for bed.
