aeroscout Posted June 4, 2012 Report Posted June 4, 2012 The Huey had a sprag clutch. The JetRanger/Kiowa has an accessory driven freewheeling unit. I don't know what the Robinson helos have, nor the 500. My question for discussion is...Which one is the all around best. Best design, operation, engineering, efficiency, simplicity, durability. Best all around, and why ? Quote
jimbo2181 Posted June 4, 2012 Report Posted June 4, 2012 This looks like a job for Superman....I mean iChris 1 Quote
helonorth Posted June 4, 2012 Report Posted June 4, 2012 Your 206 has one of them sprag clutches. Accessory driven free wheeling unit? Never heard of such a thing. Neither has my mechanic, and he's worked on helicopters for 30 years. A sprag clutch is a free wheeling unit, although I'm sure there are some other incidental parts. And vice versa. You want a discussion on what is the "best all around" free wheeling unit? 1 Quote
nightsta1ker Posted June 5, 2012 Report Posted June 5, 2012 In my limited experience (MH-47, MH-60, B206, S300C, R22) all the free wheeling units are very similar except for size. Don't let the names of parts fool you. Different manufacturers have different terms and names for what is basically the same stuff on other makes. 1 Quote
bluethunder Posted June 5, 2012 Report Posted June 5, 2012 In my limited experience (MH-47, MH-60, B206, S300C, R22) all the free wheeling units are very similar except for size. Don't let the names of parts fool you. Different manufacturers have different terms and names for what is basically the same stuff on other makes. +1 (from a former mechanic) Quote
ridethisbike Posted June 6, 2012 Report Posted June 6, 2012 +1 (from a former mechanic)Â +2Â In the Army it's a generator.... on your personal car.... it's an alternator. They both do the same thing... charge your battery. Quote
Eric Hunt Posted June 6, 2012 Report Posted June 6, 2012 Errr... a generator?? How are you associating this with a freewheel unit? And I am missing the significance of the +1 and + 2 Quote
bluethunder Posted June 6, 2012 Report Posted June 6, 2012 Errr... a generator?? How are you associating this with a freewheel unit? And I am missing the significance of the +1 and + 2 I think he was making a similar point in comparing the generator to an alternator-not comparing it to a freewheel. +1, +2 just meant that we were in agreement to what nightsta1ker was saying. 1 Quote
jimbo2181 Posted June 6, 2012 Report Posted June 6, 2012 A generator creates dc electricity an alternator creates ac. There are other differences as well. Quote
nightsta1ker Posted June 6, 2012 Report Posted June 6, 2012 Haha, I was just gonna say that jumbo, you beat me to it. Quote
jjsemperfi Posted June 6, 2012 Report Posted June 6, 2012 I'm glad this post was put up here. Anyone have a good moving animation or video of a Sprag Clutch? I've checked youtube and I've found a couple but not a helicopter specific animation. Quote
nightsta1ker Posted June 7, 2012 Report Posted June 7, 2012 Doesnt matter if it's helicopter specific or not. Sprag clutch is a sprag clutch. If the driven half is turning faster than the driving half, it's allowed to rotate independently. If the driven half slows down then the driving half engages it and they rotate together. It's really quite elegantly simple. Quote
ridethisbike Posted June 7, 2012 Report Posted June 7, 2012 A generator creates dc electricity an alternator creates ac. There are other differences as well. Correct... but in the Army it's called a generator even though it supplies A/C power to charge the battery. Mounts like an alternator, functions like an alternator, produces the same type of electricity as an alternator, but in the Army it's a generator. I think they take it to a barney level and since it generates electricity, it's a generator.  bluethunder was correct about my intended comparison. Quote
superstallion6113 Posted June 10, 2012 Report Posted June 10, 2012 +1 on what nightsta1ker said. I've worked on the CH-53D, CH-53E, CH-46E, and 5 different models of the H-60/S-70. They all work pretty much the same. The CH-53E has a slightly more complicated design to support the 4400shp engine and be smoother/faster in operation and has more parts to it internally, and it has a higher fail rate. I'd say the simple design is the best, which is what most have. Quote
nightsta1ker Posted June 12, 2012 Report Posted June 12, 2012 Found this in another thread. http://vimeo.com/35467888 1 Quote
Eric Hunt Posted June 12, 2012 Report Posted June 12, 2012 Bikerider said:Correct... but in the Army it's called a generator even though it supplies A/C power to charge the battery. Mounts like an alternator, functions like an alternator, produces the same type of electricity as an alternator, but in the Army it's a generator. What aircraft are you describing?B206? They have engine-driven generators, but that can then feed an inverter to get AC power for autopilots and some instruments. A battery requires DC power to charge it - an alternator needs to feed through a rectifier first. Quote
ridethisbike Posted June 13, 2012 Report Posted June 13, 2012 Bikerider said:  What aircraft are you describing?B206? They have engine-driven generators, but that can then feed an inverter to get AC power for autopilots and some instruments. A battery requires DC power to charge it - an alternator needs to feed through a rectifier first. A HMMWV lol Nightsta1ker: Good find. I had no idea that ALL it really is, is a one way bearing. Quote
SBuzzkill Posted July 11, 2012 Report Posted July 11, 2012 (edited) Bikerider said:  What aircraft are you describing?B206? They have engine-driven generators, but that can then feed an inverter to get AC power for autopilots and some instruments. A battery requires DC power to charge it - an alternator needs to feed through a rectifier first. OH-58 has 2 generators, one AC and one DC. Edited July 11, 2012 by SBuzzkill Quote
Guest pokey Posted July 14, 2012 Report Posted July 14, 2012 Both generators and alternators produce AC current. Both convert it to DC, but in different ways. Any device that creates electricity by spinning motion, will produce AC current. On the other hand, devices that produce electricity w/out the use of motion ( solar power, batteries) will be DC. The generator converts AC to DC via a commutator, alternator via diodes. Another interesting note, piston engine magnetos,,,,, each time it fires, one firing is positive, next is negative-----sot THAT is why we 'rotate' our spark plugs to give longer life? Sprag clutch, yes-nothing more than a 1 way bearing, there are a few different designs out there for the races tho, but? all use same principle,, lock up in one direction, freewheel in the other---automatic transmissions in cars have a few of these. 2 Quote
JBX11B Posted August 2, 2012 Report Posted August 2, 2012 I don't know if the term came from the army, Sikorsky, or GE but they were referred to as "AC Generators" on the T700 engines. The single engine Hueys had a generator driven off the front of the xmsn (D & H) and side (C & M), the starter generator was just standby and you'd switch it so after engine start. Quote
JBX11B Posted August 2, 2012 Report Posted August 2, 2012 This looks like a job for Superman....I mean iChris Yes iChris is THE MAN! Quote
herceng Posted October 5, 2012 Report Posted October 5, 2012 Left turn Clyde...Getting back on track...thanks for the video Nightsta1ker. Informative and easy to understand. Like it. 1 Quote
nightsta1ker Posted October 8, 2012 Report Posted October 8, 2012 Left turn Clyde...Getting back on track...thanks for the video Nightsta1ker. Informative and easy to understand. Like it. Don't thank me, I stole it from an earlier post here on VR! Quote
d10 Posted October 28, 2012 Report Posted October 28, 2012 In my limited experience (MH-47, MH-60, B206, S300C, R22) all the free wheeling units are very similar except for size. Don't let the names of parts fool you. Different manufacturers have different terms and names for what is basically the same stuff on other makes. It's been a while since I logged all of my 10 hours in an R22, but don't they work by tightening that belt between the engine and transmission? That's a lot different than the H-60 freewheeling unit. Quote
ridethisbike Posted October 29, 2012 Report Posted October 29, 2012 The tightening of the belts is only the clutch doing its job. The freewheeling unit works separately, whether the belts are loose or tight... or missing all together. Quote
