I am hazy on this and would like clarification. I'm an active duty Marine conducting an interservice transfer to the Army. I will be on the board in May. What I don't understand is this; am I on the same board as the civilian applicants and am I competing against civilian applicants as well, or am I only competing against other active duty applicants?
Thanks
Thanks
To my understanding you will be competing against your AD group while the civilian group is entirely separate.
Thanks
You didn't do a Battalion board, right? If not, you'll be on the AD board.
Here's an easy way to find out --
Is the board you're attending held monthly, or is it held bi-monthly? Monthly boards are held for civilian applicants, whereas bi-monthly boards are done for active duty applicants.
Even better -- I just spoke to a friend whose an Air Force IST and he said he competed against civilian applicants (and other IST applicants). So there's your answer: civilian board.... usually. ;) There's exceptions, too -- where are you doing your board interview?
Edited by zVo
Old info Zack, they switched civilian boards to every other month just under a year ago.
Bad, bad me for spreading bad information... and badness.
You're a terrible, terrible person. ;)
I can confirm, while they do the boards at the same time you will only boarded against active duty.
Thanks. Is anyone aware of acceptance rates for AD boards?
January was 48.2%.
I'm guessing May might be that...without the 4. :(
Oh hush!!!! :(
January was 48.2%.
Do you know approximately how many applicants were on that active duty board?
As far as LORs go for active duty guys, are we permitted to submit 6 as well, or only the senior Army CW LOR, battalion commander, and company commander?
Oh hush!!!! :(
Sorry Lindsey I'm a little eior-like if you haven't noticed.
What's the point...
Jag: I think it was about 160. I'm not where I can check that MILPER right now.
I think the January board thread had the AD stats and numbers.
147 I think. I can tell you for sure Monday when Im at work.
  • 1 month later...
for those AD but not in the Army, what did you wear for your board? Can you wear your branch equivalent dress uniform or just plain formal "civies?"
If your active duty, there is no board. Just the packet.
WOW! ok now i know i need some sleep. I was looking around for clarification on the Battalion Board, i read awhile back that AD didnt have to do this portion, and i got confused by this thread. This thread's "board" is refering to Selection boards, not actual face to face boards. haha sorry fellas. -__-'
