There's an AG intern position on the job page. It only requires 300 hours, but it's also 180lbs max in a 44? I'm used to seeing that as a max hiring weight for the 22, but even R44 tours are 200lbs. Why so light a pilot?
Lighter the pilot the more chemicals on board equals more money for the operator...and since there's no shortage of 300 hour pilots they could make it a 140lb max and still have plenty of applicants...
don't know about r44 rigs but on the 206 we usually run 100 gallons of mix, depending of course. mix weight can vary but figure 10lbs a gallon for a rough guess, again depending. corn, wheat, pine tree burn downs all kinds of different chemicals used with different weights.
  • 3 weeks later...
The Diabrom I spray for Mosquitos is 14-15 lbs per gallon, BVA2 oil used to larvicide weighs 8-9 lbs per gallon, and for the dry larviciding such as Vectobac CG we use 40lb bags and load as required.
I don't think its how much chemical you can carry, I think it is how much fuel you can carry... you will generally be taking the same loads every time, but they don't want someone who has to stop and fuel up every 30 minutes instead of every hour... just my thought
If I can carry an hour of fuel then I'd cut it back to 30 minutes and take the extra mix if my tank has room. Nothing wrong with getting fuel often when you're working from a truck with fuel right there.
