Fox 21 Alpha Posted March 2, 2020 Report Share Posted March 2, 2020 I'm curious if so called older aircraft like the TH-67 and the OH-58 Kiowa are still on the SIFT. I'm going through some study guide books and its seems to be a mixed bag. There's questions that have the UH-72 involved, but then they'll ask for example "Which of the following has been the Army's primary training helicopter since 1993?" and gives the UH-72 and TH-67 as options. The 1993 part makes that one easy but I'm wondering if there could be other less clear questions. The one that got me aggravated was "Which of these Army helicopters is the lightest (ie lowest empty weight)?" and gives "Bell Th-67" and "OH-58A Kiowa". I picked the 67 but apparently the A model of the OH-58 weighs next to nothing. It was the only time they added on the A model, the rest of the test simply says "OH-58 Kiowa". I tried looking up weights but it seems sketchy and most websites aren't clear on exact weight for different variants of the same modelIs the test that convoluted? Quote Link to comment Share on other sites More sharing options...
Crash7051 Posted March 3, 2020 Report Share Posted March 3, 2020 they were never complex question when it came to aircraft type. It was more like what's the utility helicopter, or the heaviest etc... They were pretty straight forward questions. I don't remember any trainer questions. But know which one is which Quote Link to comment Share on other sites More sharing options...
Wolf359 Posted March 3, 2020 Report Share Posted March 3, 2020 Keep in mind that there’s no “official” SIFT study guide and the questions aren’t released in any format, so most of the ones you find online are just people’s best guesses on what the test will entail. If I remember correctly, Accepted Inc. was the closest, but it still had plenty of stuff in the guide that wasn’t present in the actual test. Quote Link to comment Share on other sites More sharing options...
parking Posted March 11, 2020 Report Share Posted March 11, 2020 It shouldn't be down to an exact submodel. The aircraft portion should be easy. If you're on this forum already, you will have no issues on that section. Quote Link to comment Share on other sites More sharing options...
Fox 21 Alpha Posted March 12, 2020 Author Report Share Posted March 12, 2020 Yeah I took it last week and it was my strongest section I think. It had previous obvious bad choices assuming you knew the difference between a tail rotor and a main rotor. I also studied this section the most I think. There were a couple zingers, like the class G airspace, and you had to know slip and skid and the basics but it wasn’t bad. For the aircraft the questions were pretty straight forward. They had other aircraft on there, including foreign ones and older ones, but it was easy questions, like pick which one is a US Army helicopter. Mig would not be the correct answer... Quote Link to comment Share on other sites More sharing options...
