PhotoFlyer Posted May 30, 2008 Report Share Posted May 30, 2008 One of my students showed me the following picture of an Alouette II and asked me what the cables that are attached to each blade are for. I'm not sure if they run from blade to blade, or from blade to mast, and I have absolutely no idea what it is for. Thanks! Quote Link to comment Share on other sites More sharing options...
jfcorey Posted May 30, 2008 Report Share Posted May 30, 2008 One of my students showed me the following picture of an Alouette II and asked me what the cables that are attached to each blade are for. I'm not sure if they run from blade to blade, or from blade to mast, and I have absolutely no idea what it is for. Thanks! Those are lead/lag restraints, essentially fail-safes in the event of a failed damper Quote Link to comment Share on other sites More sharing options...
helonorth Posted May 30, 2008 Report Share Posted May 30, 2008 (edited) One of my students showed me the following picture of an Alouette II and asked me what the cables that are attached to each blade are for. I'm not sure if they run from blade to blade, or from blade to mast, and I have absolutely no idea what it is for. Thanks! Droop stops? Or maybe dampeners. Edited May 30, 2008 by helonorth Quote Link to comment Share on other sites More sharing options...
Paddy Posted June 1, 2008 Report Share Posted June 1, 2008 They are going between blade to blade and they are there to keep the distance between the leading blade and the trailing blade. Just to keep the distance and avoid a complete distorsion of the head or the arms. Quote Link to comment Share on other sites More sharing options...
Witch Posted June 2, 2008 Report Share Posted June 2, 2008 Prevention of ground resonance? Later Quote Link to comment Share on other sites More sharing options...
ricardix81 Posted June 2, 2008 Report Share Posted June 2, 2008 Hello. I work whith alouette III and those cabres, just like it was said, are to keep the same distance beetwin the blades. the blades have orizontal movment, and those cables do the to mantai the same distance from one blade to the others.Sory mi inglish Quote Link to comment Share on other sites More sharing options...
bossman Posted June 3, 2008 Report Share Posted June 3, 2008 Blade spacing. Quote Link to comment Share on other sites More sharing options...
