Don't know if anyone has posted this yet, but the WCVB News 5 chopper in Boston made a perfect night auto on the Boston Common.
Video is here
Chris
Not entirely sure that was an auto. If you turn the volume up loud enough, it just about seems like the pilot rolls off the engine throttle after he sets the aircraft down. Think it was just a power-on precautionary landing.
Edited by RagMan
N1 Tach Gen failure. Not really a reason for an immediate landing, but whatever. PHI doesn't even have the engine out audio installed anymore for that exact reason. Horn goes off, pilots initiate auto instead of checking gauges and realizing their aircraft is still running.
That's one reason I always do N1 tach fails in the simulator with my students! They fall for it EVERY time, until I show them what else to look for.
Not sure if it was a N1 tach fail or full blown auto but the pilot sure sounds stressed AlsoI think this clip goes to show that in a Heli when something goes wrong, you might notify ATC, but you'll be on the ground before they realize what happened.
Taken from LiveATC.net
N55TV-Boston-Commons-Landing-Jan-11-2255Z.mp3
When you do your N1 fail do you expect the pilot to start Auto procedure at same time as scanning, or scan, then collective down ? with a low hour pilot it could make the difference
I've had N1 tach gen failure where the engine out light/horn came on in a 500 and even though I got a shot of adrenaline and my eyes instantly went to the dual tach I knew immediately that I had not had an engine failure from sound/feel.
I give him credit for getting it down safely. Its easy to judge after the fact. Everyone is safe and ship is ok...great job
Generally with a low time pilot I expect them to start the auto then IF TIME PERMITS, ask themselves. Was that like a typical engine failure we practiced before? Did I Yaw as expected? Does the engine sound like it's winding down? What is N2/NR doing? Where is the N1 Gauge sitting? Then (and I stress IF TIME/ALTITUDE PERMITS) Pull a little collective.... does it feel like you're under power? Does the NR drop? etc...
Couldn't agree more ChprPlt, just saying I like all my turbine students to practice N1 fails. Not trying to armchair the pilot of this incident.
